rocker cover/ engine help
i have got hold of a 2006 s2000 engine for my 1999 car and will be installed in the next few days ,
apart fromt the breather outlet whih i can get the hose on are the rocker covers any different?
i would like to use the 2006 one as the paint finish is much better
***update***
chrisr said:
If the '06 cover was from a DBW S2000 it will not work on a '99.
There are two TDC sensor on the '99 cover, but there is only one on later model DBW cars.
- i have already fitted my stock 99 inlet manifold and ancilleries to the bare engine, other then swapping my rocker cover is there anything else i need to be aware of before fitting it?
***update***
UK Moderator
Chris.
Chris.
if i put my 99 rocker cover on then the engine will work yes?
i have fitted my 99 inlet manifold and ancileries already.
thanks mate your a LEGEND!!!
have my 99v jdm inlet manifold, fuel system and cam cover fitted, engine should be in this afternoon or tomorrow morning
cheers for your help and knowledge
51mes
06-22-2015 03:53 AM
