roof/door leak
Hi there. Got the classic leak where everyone with a seat gets a lovely shower when i first pull off invyhe car. Now iv read the massive thread on this along with other posts but im getting a bit confused. Partly because most pictures are no longer available to view and partly because there appears to be no clear resolution. Any further help is appreciated. Well soap at the ready Im off for my morning shower now.
john |
I had that for years and could not figure out what to do - followed all the advise and nothing worked. Then I decided to replace the soft top and the chap at Carhood Warehouse resited the rubber seals properly. That was 9 years ago and I've not had the problem since.
Originally Posted by Brailer
(Post 24466205)
john some have found replacing the elastic tensioners has helped plus the famous Shinetsu grease on the seals. |
Got some shin etsu grease on the way as the seals do look like then need it. Good tip on the photos il have another look. I imagine the issue is either one or all of the following: dry/old, seals, disintegrated foam inserts, worn out roof.
(Post 24477495)
Leaking is quite bad now... Help!
