roof/door leak - S2KI Honda S2000 Forums
Notices
roof/door leak
Old 05-28-2018, 02:53 AM
Default roof/door leak
Hi there. Got the classic leak where everyone with a seat gets a lovely shower when i first pull off invyhe car. Now iv read the massive thread on this along with other posts but im getting a bit confused. Partly because most pictures are no longer available to view and partly because there appears to be no clear resolution. Any further help is appreciated. Well soap at the ready Im off for my morning shower now.
john
Brailer is offline
Old 05-29-2018, 01:53 AM
I had that for years and could not figure out what to do - followed all the advise and nothing worked. Then I decided to replace the soft top and the chap at Carhood Warehouse resited the rubber seals properly. That was 9 years ago and I've not had the problem since.
tjockhult is offline
Old 05-29-2018, 04:53 AM
richmc's Avatar
john
Funny you say that go back and have another look at the threads, photobucket have just reinstated their service, photos may be back..
some have found replacing the elastic tensioners has helped plus the famous Shinetsu grease on the seals.
richmc is offline
Old 05-29-2018, 10:22 AM
Got some shin etsu grease on the way as the seals do look like then need it. Good tip on the photos il have another look. I imagine the issue is either one or all of the following: dry/old, seals, disintegrated foam inserts, worn out roof.
Brailer is offline
Old 06-20-2018, 11:03 AM
Leaking is quite bad now... Help!
Brailer is offline
Old 06-21-2018, 01:45 AM
Irish TuneR's Avatar
Do as Richmc said above and look at thread again as it has the pics back. If you're happy your roof is good i'd take off the seals and give them a good look over for cracks/holes, redo the foam seal and reinstall them.
Irish TuneR is offline
mysterioJR
08-28-2015 03:06 PM
DanielSan
08-04-2013 09:17 AM
s2konroids
05-15-2012 10:36 AM
zagamuffin
10-06-2010 04:54 AM
Fatbloke
02-10-2009 03:01 PM
Quick Reply: roof/door leak
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
