Roof Seating Correctly When Down?
Old 04-26-2019, 01:26 AM
richmc's Avatar
Originally Posted by gingerphil View Post
Hello again,
Thanks for the replies.
Visually the elastic straps look ok, but when I pull on them I would describe their elasticity as a little disappointing. There's a bit there, but not a lot.
That sounds correct there shouldn't be much movement in the elastic.
This is what it looks like with poor elastic, note the "hump" behind the head reasts, yours doesn't do that.
This would be bad.
This is good you can get your fingers in, just.
richmc is offline
Old 04-29-2019, 01:35 AM
Thanks for the useful replies, I haven't yet managed to have another look at the car. I've ear marked some time for tonight thought.
I'm sure that I was opening it all of the way, until the motor stalled. I also think despite not being the cause of this, my elastic roof straps are way past their best and would benefit from a replacement. My plan is to pick up some suitably sized elastic and simply velcro them around the bars rather than mess about with the existing rivet fixing, unless anyone has a better suggestion.
I think the replies from Martin/Richmc have confirmed that I have something else which is not quite right and allowing the roof to move about like it is.
Hoping for a quick diagnostic and simple fix, if only I had noticed this before I had sorn the car back in October!
gingerphil is offline
Old 04-29-2019, 05:12 AM
martin j's Avatar
Mine has been out today (as has the sun) so here is picture so can compare roof line height. HTH.
martin j is offline
Old 04-29-2019, 06:11 AM
Chuck S's Avatar
Looking at the fold in the fabric at the center bottom of the photo the roof still looks only partially open. Mostly open for sure but this may be where the slack in the system is. Here's mine 10 minutes ago. Ignore all the dust, it's pine pollen season here in Virginia. Car was washed two days ago and in the garage with the door closed.
-- Chuck
Chuck S is online now
Old 04-30-2019, 12:09 AM
richmc's Avatar
If you still want to replace the roof elastic, see here.
https://www.s2ki.com/forums/uk-irela...w-fix-1019070/
richmc is offline
Old 04-30-2019, 02:06 AM
I did see that earlier but had it in my mind I wanted to use velcro, now I've given it a proper read I'll be using your method, thanks again!
I also had a look at the roof in more detail last night, with it partially down the front part of the roof and hinge mechanisms all seemed to move about a bit, but as far as I could see the bolts were all welded on so could not be tightened.
I think I may have to take it to someone to check it out for me.
Cheers
Phil
Old 04-30-2019, 04:38 AM
martin j's Avatar
No other member in your area to meet and make a comparison?
martin j is offline
Old 04-30-2019, 11:47 PM
There's an event local to me this weekend actually, with S2000's in double figures!
I won't be able to make it though I don't think
sound_wave
06-23-2014 01:06 AM
Quick Reply: Roof Seating Correctly When Down?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
