Rotor Rubbing in one Area - Help!
Old 01-26-2019, 06:21 AM
noodels's Avatar
Maybe a S/H hub 40-50
Old 01-26-2019, 08:40 AM
Nick Graves's Avatar
I'd try sanding the high side of the face back to bright steel first.
It's hardly anything 'out'
Old 01-26-2019, 09:23 AM
Fellblade's Avatar
Not a bad idea. It's not much out but clearly enough to affect the braking! I'll give it a shot...
Old 01-27-2019, 01:05 AM
Fellblade's Avatar
Well, an hour and a half of freezing temperatures later with some 320 grit wet & dry and the hub is reading a max of 0.01mm out and the disc has a max of 0.03mm
I was intending to try and improve a little more, but I had to give up when I couldn't feel my feet or fingers any more
Old 01-27-2019, 04:22 AM
Daytona-Dave's Avatar
They are well within spec and would be surprised if they cause an issue to be 100% you can have the discs skimmed in-situ which accounts for any hub or mounting problems
Heavyd53
03-16-2016 08:18 AM
Greg W
10-23-2010 03:06 AM
Nickfromny
18
04-29-2005 06:35 AM
cordycord
03-12-2005 10:25 AM
SAIYAJIN
01-21-2004 05:21 PM
Quick Reply: Rotor Rubbing in one Area - Help!
