S200BCW, anyone know anything about this car?
Hi guys, might be looking at an s2k with the above plate, does anyone know anything of its history?
Thanks
Thanks
Registration number: S200BCW
- Vehicle makeHONDA
- Vehicle modelS2000
- Date first used28 March 2002
- Fuel typePetrol
- ColourSilver
MOT history of this vehicle
- Test date7 January 2017
- Expiry date6 January 2018
- Test ResultPass
- Odometer reading93,092 miles
- MOT test number3874 9055 2430
- Advisory notice item(s)
front tyres close to wear bars
nearside rear tyre close to legal limit
offside rear tyre close to wear bars
- Test date11 November 2016
- Test ResultFail
- Odometer reading92,573 miles
- MOT test number4451 6753 0063
- Reason(s) for failure
Parking brake: efficiency below requirements (3.7.B.7)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.3)
Nearside Rear Headlamp levelling device obviously defective headlamp level sensor has broken link rod & seized ball join (1.7.2)
Nearside Front Headlamp aim too high and too far to the right. (1.8)
Offside Front Headlamp aim too high and too far to the right. (1.8) - Advisory notice item(s)
Supplementary Restraint System warning lamp does not illuminate (5.4.2)
Engine management warning light on.
- Test date17 October 2015
- Expiry date16 October 2016
- Test ResultPass
- Odometer reading89,988 miles
- MOT test number6578 9109 5444
- Test date3 October 2014
- Expiry date13 October 2015
- Test ResultPass
- Odometer reading82,996 miles
- MOT test number6498 5637 4239
- Test date2 October 2014
- Test ResultFail
- Odometer reading82,990 miles
- MOT test number6179 4527 4247
Offside Rear Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a) - Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
- Test date14 October 2013
- Expiry date13 October 2014
- Test ResultPass
- Odometer reading73,365 miles
- MOT test number3161 6708 3216
- Test date9 October 2012
- Test ResultFail
- Odometer reading65,799 miles
- MOT test number4196 1348 2280
Nearside Headlamp aim too high (1.8)
Offside Headlamp aim too high (1.8) - Advisory notice item(s)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
- Expiry date13 October 2013
- Test ResultPass
- MOT test number8073 7328 2215
- Test date7 October 2011
- Expiry date13 October 2012
- Test ResultPass
- Odometer reading59,868 miles
- MOT test number4850 8018 1236
Nearside Rear Direction indicators slightly discoloured (1.4.A.2f)
Offside Rear Direction indicators slightly discoloured (1.4.A.2f)
- Test date14 October 2010
- Expiry date13 October 2011
- Test ResultPass
- Odometer reading52,863 miles
- MOT test number8044 9718 0249
Front Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
- Test date14 October 2009
- Expiry date13 October 2010
- Test ResultPass
- Odometer reading45,494 miles
- MOT test number9648 4768 9270
- Test date29 August 2009
- Expiry date5 September 2010
- Test ResultPass
- Odometer reading44,839 miles
- MOT test number9216 1174 9239
- Test date27 August 2009
- Test ResultFail
- MOT test number8604 4943 9261
Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Rear Brake pad(s) less than 1.5 mm thick (3.5.1g)
- Test date6 September 2008
- Expiry date5 September 2009
- Test ResultPass
- Odometer reading39,460 miles
- MOT test number1418 3035 8232
- Test date30 August 2008
- Test ResultFail
- MOT test number7308 7364 8233
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1) - Advisory notice item(s)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
both front tyres worn on inner edge
- Test date9 August 2007
- Expiry date8 August 2008
- Test ResultPass
- Odometer reading30,260 miles
- MOT test number2602 3142 7285
- Test date20 June 2006
- Expiry date29 June 2007
- Test ResultPass
- Odometer reading20,453 miles
- MOT test number5144 7167 6140
- Test date30 June 2005
- Expiry date29 June 2006
- Test ResultPass
- Odometer reading8,580 miles
- MOT test number8535 8188 5122
That's a lot of fails for any Honda!
Owner must be a right dick having all those tyre fails and advisories, you would think he'd learn to check them before going for the MOT after the first couple of fails.
Depends on if the same person has owned it for a long time or not tbh, S2000's have quite a high owner turnover compared to alot of cars (as most sports cars do really)
2017 - worn advisory
2015 - cut in a tyre failure
2012 - worn advisory (x2, failed on headlights and retest)
2008 - worn tyres fail
Guy seems to have driven it for about 500 miles on a failed MOT.
Failed on 11th Nov, retest 500 miles and 2 months later.
For the OP, if its not too far, best is to go and have a look.
Also download "Vehicle Smart" app. Just need a reg and vehicle make. Gives you MOT history, Mileage History and a few other bits.
A mate used it the other day and found his old truck had been majorly clocked. MOT X had 174K on, Next MOT it had 62K on it.
Wow thanks for the replies!
Yes I had checked the history online and seen all that.
Curent owner had it since January, took is at a part ex and needs a van for work or something of the like, seems fault genuine.
So the previous owner to him did the 500 miles without mot, and current owner wouldn't accept swap with a new mot. I can only assume it's changed hands a lot but all the other mot suggest just tyres really so not too bad.
Although what it failed on was decat related so nothing major I assume? Also Ive seen a lot of these cars with headlight issues in the mot now why is that, I'm hoping they've not all had front end impacts or something?
Cheers
Cheers
Tyre wear could be down to bad geo. And if the bolts are seized, then you have a very fun job at hand.
If you can do it yourself and have the tools, then set a good weekend aside.
If you dont and take it to a garage, expect much £££ to cut out and replace seized bushes.
also ive been told there are small arch bubbles on the rear arches (where else)
how much should i budget to fix that?
or as a temporary thing can you sand these down, use kurust then touch them up? i know it will come back but gives me time to save til i can afford to get it cut out properly etc
