S2K Tuning with ME221
Old 03-11-2019, 11:36 PM
mtunreal's Avatar
Liked 9 Times in 9 Posts
Default S2K Tuning with ME221
Recently had my car tuned and set up on the fantastic ME221 from Motorsport Electronics. Really chuffed with the results, with this being the first dedicated ECU for prefacelift S2K's. The support/advice from Motorsport Electronics have been excellent, helping me get the most out of the ECU. Major benefit of having a UK based company on hand who are willing to help their customers. Its good to know that the car is still healthy and the AFR's have been smoothed out throughout the band. Ready for the season of racing ahead.
If anybody is looking for an S2000 ECU, I can not recommend Motorsport Electronics enough. Its so reassuring to know the chaps there are ready to help with their awesome bit of kit. Cheers guys.
mtunreal is offline
Old 03-12-2019, 12:34 AM
Liked 0 Times in 0 Posts
Looks great !
I was thinking about going with the doctronic proecu-s2k, but this one can also be great !
Does the dashboard coolant temperature gauge work well ?
Any modification on sensors ?
Dos it retain OBD fully functional ?
pizzai69 is online now
Old 03-12-2019, 12:54 AM
I'd be interested to hear your thoughts on this as this was the ECU I was planning on using, after it got some good reviews in the MX5 community.
Looking at the photos, you look to be still N/A, so what results did you get? I hear you can pick up a chunk of torque in the mid range even though it may only be a few HP at the top end.
They sell this as a PnP solution, and say that it utilises all the stock sensors and dash functionality, is this correct? What kind of issues did you experience with it when installing and setting up?
Thanks
C
ChrisPackit is offline
Old 03-12-2019, 04:20 AM
nomadicS2k's Avatar
Liked 15 Times in 15 Posts
Hi MT, I just pinged you on FB post about the ecu - Agreed with ChrisPackit - does the temperature gauge work correctly and wideband?
@ChricPackit - The gains will be in the midrange, with just a few horses at the top - the benefit was a reduced vtec cross over too. I had full supporting mods too - full exhaust, decat, larger throttle body, CAI. Good for a few more horses and throttle response.
nomadicS2k is offline
Old 03-12-2019, 07:17 AM
mtunreal's Avatar
ECU is plug and play, uses the factory harness. No modification to wiring or sensors. No OBD functionality, however with a cheap windows laptop/tablet you can inspect everything the ECU is doing including diagnostics.
No major issues with set up or tuning, everything went a breeze. Had a small issue with one setting, which ME put right straight away.
Coolant gauge I would say, rises slightly faster than the OEM unit (quicker up to 3 bars), however this can be adjusted in the ECU I believe (can decide when each bar is lit up). Crank is like AEM with a double cycle before firing.
As Nomadic says, its mainly mid range.
mtunreal is offline
Old 03-12-2019, 07:47 AM
BenRNBP's Avatar
Liked 22 Times in 20 Posts
tbh the Honda ECU fires up too soon, good to get some oil circulating while the ME221 works out where it is in the timing cycle and just love this first road test vid, the lower vtec engagement does seem to make a difference
BenRNBP is online now
Old 03-12-2019, 08:59 AM
mtunreal's Avatar
More oil around first is always good. Just to note for those unfamiliar with how Non OEM fires up. Lowering the VTEC feels like it improves the linearity of response in the revs. With the foot buried it just keeps pulling, no lul before VTEC.
mtunreal is offline
Old 03-12-2019, 10:52 AM
noodels's Avatar
Liked 57 Times in 56 Posts
A sort of cringe on starting my <oem ecu> S from cold,as its starts too quick and revs tooo much
noodels is offline
GaryB
09-10-2012 01:09 AM
P.J.
06-13-2012 01:17 AM
jadrice
07-23-2010 08:30 PM
ultimate lurker
07-26-2001 11:45 PM
Pixsurguy
07-16-2001 02:46 PM
Quick Reply: S2K Tuning with ME221
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
