Notices
Sad day for my s2000
Old 01-26-2019, 11:26 PM
unclefester's Avatar
Liked 25 Times in 24 Posts
Andy is still active ( he's back in the UK ) and still just as colourful to talk to
unclefester is offline
Old 01-27-2019, 01:15 AM
E4RTH WORM JIM's Avatar
Liked 19 Times in 19 Posts
Originally Posted by arsie View Post
Is that what's happening in your avatar? Only just noticed.
You might have heard of Normal for Norfolk but East Yorkshire looks a whole lot more interesting
Had fhat fecker for about 10 years and you’ve only just noticed!
E4RTH WORM JIM is offline
Old 01-27-2019, 08:16 AM
Jub
Liked 8 Times in 7 Posts
I agree with the sentiment of replacing it with a used OEM one. I'd definitely not order parts before having someone take it apart, if repairing. I don't know much about diffs tbh, but I'm pretty sure the torsen LSD is usually still good in the event of a failure. It is usually the smaller drive gear (I think pinion gear) that breaks. Isn't the MFactory diff also just another torsen? I don't think there is a compelling reason to swap LSD's to a different torsen type than OEM. I'd only stray from the OEM torsen if moving to a clutch type or the like. Either way, I'd probably go OEM on a stock street car or have puddymod rebuild/upgrade..
Jub is offline
Old 01-27-2019, 08:31 AM
OAP
Liked 0 Times in 0 Posts
I think i am going to go for a used unit.
The mechanic its with didn't give me much of a description apart from the LSD's gone bang.
He says... "He'll contact a friend with a better idea of options for me" but also said he'd happily fit a used one.
I just want my Honda back as its the only car I have
OAP is offline
Old 01-27-2019, 10:29 AM
Nottm_S2's Avatar
Liked 56 Times in 56 Posts
its a few hours to swap, rebuilding is expensive and failure rare enough on std cars
upgrades are north of a bag i believe - EWJ had to import from the US and it aint cheap
Nottm_S2 is offline
Old 01-29-2019, 08:20 AM
OAP
Well the garage ended up finding one for me in the end £280 + Fitting so not all bad.
Will have my S back for the weekend
Thanks for the help guys.
OAP is offline
Old 01-29-2019, 10:39 AM
Nottm_S2's Avatar
problem i had was prop bolts were rusty and didnt survive extraction
they were back order and took weeks, in the interim i just used some high tensile ones but the bolt place reckoned the oem were weird spec so i swapped em when the honda ones arrived
make sure they use the righr diff fluid
Nottm_S2 is offline
Old 01-29-2019, 11:03 AM
OAP
I have a bottle of Castrol Syntrax 75W90... I believe that to be the right stuff.
Will hand it to them tomorrow for piece of mind .
OAP is offline
Old 01-30-2019, 12:35 PM
Nick Graves's Avatar
As long as it's a 90 w EP oil (the one that stinks of sulphur) it'll be OK.
I think some Honda garages aren't used to hypoid gears and put the normal transmission oil in.
Nick Graves is offline
Dithrain
12-11-2015 05:41 PM
S2Malo
05-11-2013 12:07 PM
Brock227
12-19-2012 10:49 AM
pwrofdrm
30
02-02-2007 01:21 AM
demonderrick
10-22-2002 08:33 AM
Quick Reply: Sad day for my s2000
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
