Second hand rims, will they fit?
Hi, I've read the wheel / tyre fitting, but it's all foreign to me so wanted to double check.
They're the old volk racing gt-c rims and spec is:
5 x 114, offset 44, 17" 8.5j front 17" 9.5j rear
Any info would be great!
Thanks.
Thanks.
OEM Alloys
OEM MY00-03 wheel sizes and offsets are as follows:
Front: 16" x 6.5", +55 offset
Rear: 16" x 7.5", +65 offset
OEM MY04+ wheels are as follows:
Front: 17" x 7.0", +55 offset
Rear: 17" x 8.5", +65 offset
AS PER THE FAQS
AS PER THE FAQS
wheels will probably rub without doing any modifications to the arches and adding negative camber
I'm sure one of the guys like R8yb will be here to answer your questions
Originally Posted by richmc,Jan 23 2011, 05:14 AM
OEM Alloys
AS PER THE FAQS
AS PER THE FAQS
AS PER MY TOPIC.
Was going to make a bid for them, but if you have to modify the original car just for some alloys, then it's not for me.
Thanks,
Al.
Originally Posted by r8byb,Jan 23 2011, 07:23 AM
If your not lowered more than 40mm and have your geometry set for -2 at the rear which is conservative they'll fit fine
