seized bolts
Old 09-28-2017, 03:08 AM
Fergal's Avatar
Default seized bolts
Hi Everyone
Just after some advice, just had my car hunter aligned, the guy said that he could not adjust the passenger side rear as the bush was seized and is way out of alignment, what can i do to fix this, what do i have to order? any ideas?
Old 09-28-2017, 03:26 AM
mikefifth's Avatar
Originally Posted by Fergal
Hi Everyone
Get the hacksaw out and speak with Si @ Hendy for a price on a new geo bolt.
Old 09-28-2017, 03:36 AM
Daytona-Dave's Avatar
If it's a rear they can sometimes be freed off with the right gear
Old 09-28-2017, 05:57 AM
Nottm_S2's Avatar
Not had the rear sieze, is it just camber and toe adjustment so two bolts?
worst case if you cant find a mechanical superman like Ray is you cut them out, grease the shit out of your new uns and pop them in
Old 09-28-2017, 06:20 AM
ValveBounce's Avatar
Use a marine grease, or something like Wurth AL1100, which will protect them properly long term.
Old 09-28-2017, 06:35 AM
BenRNBP's Avatar
lol, the "right gear" is a lump hammer it's the only bush bolt you can get a decent swing angle to hit. Seriously though if you don't want to ruin the bolt like I did then you could use one of those ball joint presses that looks like a G-cramp to press the bolt out.
I greased mine with Corrosion Block ACF-50 Corrosion Block - Anti-Corrosion compound, oil and grease and that's done the trick for a number of years now with no re-greasing.
Old 09-28-2017, 10:07 AM
Fergal's Avatar
Hi, yes it is the camber and toe, will try and look which bolts i need, thanks
Old 09-28-2017, 11:09 AM
Nottm_S2's Avatar
There are parts diagrams on lings which make it easy, the adjuster bolts have a a cam on a sleeve and i'm sure are just called adjustment bolt by Honda
they are not cheap but not crazy money
Old 09-28-2017, 01:09 PM
Fergal's Avatar
Smile seized bolts
Thanks for your answer guys, have e mailed Hendy for costs.
Old 09-28-2017, 01:33 PM
if your cutting them out you'll need all new bushes as well
Quick Reply: seized bolts
