Service costs/location/questions
Hi all ....
wanting to get the S2k serviced and is due on time anyway .
It’s had a full Honda service life and rightly or wrongly I want to keep that up .
I’ve noticed going through the paperwork that it seems to never had the spark plugs changed or the valve clearance checked ..... when are these due ?
The cars done 27500 miles ( 04 plate ) so think of getting the plugs /valves clearance and service done at a local Honda dealership .
What should I be expecting to pay for this ?
Im in Southampton..... could anyone recommend a dealership near by that have a good reputation for the s2000?
Any help much appreciated
You should get the sheet with each service. They should both have been done on a car that age.
double check. Plugs an easy DIY.
UK Moderator
The service schedule is in the Tech FAQ here: https://www.s2ki.com/forums/uk-irela...6/#post5798519
Booti has seen km, not miles, so spark plugs are, in fact, every 54k miles or every 6 years.
Valve clearances every 27k miles or every 3 years.
Honda do fixed price servicing for cars older than 3 years, and you can find the details here: http://www.honda.co.uk/cars/owners/3-years-plus.html choose a Honda 12 and add in the extras you want according to the schedule.
I guess Hendy in Soton will look after you well. Speak to Si on here: https://www.s2ki.com/forums/uk-irela...thread-852693/
Bodyboarder1981 (01-16-2018)
I'd get the valves done, I'm not sure the clearances out of the factory are that spot-on ( https://www.s2ki.com/forums/s2000-un...ervals-991052/ ) as for plugs there's probably nothing wrong with them but I'd get them done anyway.
Give Hendyperformance a call for prices, I'm sure the new workshop can cope with an S2000 and you'd presumably a Honda stamp in the book with that.
Thanks chaps ... Much appreciated
Phoning around and coming in at £170 for the service ( minor) £100 for valve check ..... and £160 for plugs . It’s the plugs I have an issue with , as to do the valves clearance checks most of the work is done and yet they are still charging £90 to do the plugs ( assuming the plugs are around the £20 each )
UK Moderator
What’s the chances of the dealer fitting my supplied plugs though ? Slim I would image
UK Moderator
