Service costs/location/questions
Old 01-15-2018, 10:27 AM
Member
Bodyboarder1981's Avatar
Default Service costs/location/questions
Hi all ....
wanting to get the S2k serviced and is due on time anyway .
It’s had a full Honda service life and rightly or wrongly I want to keep that up .
I’ve noticed going through the paperwork that it seems to never had the spark plugs changed or the valve clearance checked ..... when are these due ?
The cars done 27500 miles ( 04 plate ) so think of getting the plugs /valves clearance and service done at a local Honda dealership .
What should I be expecting to pay for this ?
Im in Southampton..... could anyone recommend a dealership near by that have a good reputation for the s2000?
Any help much appreciated
Old 01-15-2018, 01:39 PM
Booti's Avatar
Wow. That’s a low mileage car
valves are suggested at 45,000 miles or three years. Spark plugs are 90,000 miles or six years.
Old 01-15-2018, 03:17 PM
Nottm_S2's Avatar
You should get the sheet with each service. They should both have been done on a car that age.
double check. Plugs an easy DIY.
Old 01-15-2018, 10:49 PM
UK Moderator
lovegroova's Avatar
The service schedule is in the Tech FAQ here: https://www.s2ki.com/forums/uk-irela...6/#post5798519
Booti has seen km, not miles, so spark plugs are, in fact, every 54k miles or every 6 years.
Valve clearances every 27k miles or every 3 years.
Honda do fixed price servicing for cars older than 3 years, and you can find the details here: http://www.honda.co.uk/cars/owners/3-years-plus.html choose a Honda 12 and add in the extras you want according to the schedule.
I guess Hendy in Soton will look after you well. Speak to Si on here: https://www.s2ki.com/forums/uk-irela...thread-852693/
Bodyboarder1981 (01-16-2018)
Old 01-15-2018, 10:57 PM
BenRNBP's Avatar
I'd get the valves done, I'm not sure the clearances out of the factory are that spot-on ( https://www.s2ki.com/forums/s2000-un...ervals-991052/ ) as for plugs there's probably nothing wrong with them but I'd get them done anyway.
Give Hendyperformance a call for prices, I'm sure the new workshop can cope with an S2000 and you'd presumably a Honda stamp in the book with that.
Old 01-16-2018, 01:22 AM
Member
Thanks chaps ... Much appreciated
Old 01-16-2018, 06:14 AM
Member
Phoning around and coming in at £170 for the service ( minor) £100 for valve check ..... and £160 for plugs . It’s the plugs I have an issue with , as to do the valves clearance checks most of the work is done and yet they are still charging £90 to do the plugs ( assuming the plugs are around the £20 each )
Old 01-16-2018, 06:32 AM
UK Moderator
lovegroova's Avatar
Honda do tend to charge a lot for the plugs themselves (Cox do them for £67) but you can get them for about £10 each from Opie Oils https://www.opieoils.co.uk/p-64114-n...lectrodes.aspx
Old 01-16-2018, 06:39 AM
Member
What’s the chances of the dealer fitting my supplied plugs though ? Slim I would image
Old 01-16-2018, 06:46 AM
UK Moderator
lovegroova's Avatar
My dealer has done it in the past (same goes for oil, although they are usually pretty good value on that front).
Quick Reply: Service costs/location/questions
