Shell Unleaded & V Power
As long as it is a UK spec car (i.e. not JDM) it will not make much of a difference. I have noticed that I get better mileage with V Power than Momentum, but the performance is the same. Regular unleaded is fine as well. Like almost all modern cars, the ecu will compensate for the fuel, within reason.
Member
It will run fine. You won't do any damage as the knock sensor will retard the ignition timing to compensate, you may feel a slight drop in performance and fuel economy but it's negligible.
I always stick super in as it's mapped for that ron from the factory but 95 will be fine.
Yeah I did notice that when running on 95 the car didnt seem to have any better mileage consumption, when having to fill up with 95 I thought hmmmm being cheaper i will get more miles out of this tank and it was'nt the case at all!! Is there a reason for this as some people have been saying on here they have been running 95 for 3 years or so, add that up and its a lot of miles they are missing out on by not using high octane fuel.
I think one reason is you have to push the peddle harder to get the desired effect.
There's probably some tech reason that will pop up later in the thread.
The day I bought my S I looked up the nearest Shell station on the sat nav to buy some v-power but it turned out to be some tiny little shell petrol station that didn't have v-power So I put £20 of regular in to get home then its drank nothing but the good stuff since.
Can't comment on performance difference as the car was new to me at the time. Didn't run rough though.
Administrator
