Originally Posted by mikey k,May 2 2009, 09:55 PM
After all it is important it works properly ;)
But flairing a pipe isn't rocket science. Important bit is a clean cut of the pipe :) |
Hello mate
brake lines on all cars can be replaced if needed, on the s from memory, the pipes are in a plastic cover along the length of the car, If you do need to replace them firstly you will need a flaring tool flaring tool and a pipe bender pipe bender and also some cunifer(copper nickle ferros) brake pipe (non corrode),and some compression fittings. or there is a kit as below car parts direct It is amazingly easy to replace bakelines with very little experience, the fiddly bit is bleeding the system, but if you use the guidelines in the honda manual you should have no problems Or as hypersonic said, you may have enough play just to replace the end |
Thanks for the advice shepp, that was spot on!
I've been under the car today and had a good look at the brake lines. I'm going to replace both the rear lines as I have found some corrosion on both near the rear sub frame. Managed to borrow the tools off a guy at work as well. |
[QUOTE=Carwyn,May 2 2009, 08:51 PM] Mine failed the MOT last mont for corroded rear brake lines. New rigid lines from Honda cost me about
Originally Posted by Hypersonik,May 3 2009, 08:03 PM
Nice one - get some nice pics of teh job up here :)
[QUOTE=ade73,May 3 2009, 06:59 PM] I had both sides front to rear pipes supplied and fitted by local indy for
I've seen them bolts! one at each side?
If so, they look like a PITA to un-do! |
