Soft top cleaner and waterproofer
Raggtop. That is all I and the previous owner used on mine.
Whatever your top vinyl or mohair, if it's got green on it start with Milton the stuff you clean babies bottles with, then the cleaner and protector of your choice. you have to get it back to a sterile state.
Cheers Rich
I'm a bit nervous about using Milton. I've seen what is does when it gets in contact with clothes and can easily bleach it.
I've used a spray mould and mildew remover before but the McGuire's cleaner has a built in mould ingredient which seems to work ok
I'm going to try a couple of the recommended products (thanks all) and see what results come back. My roof is 9 years on the car and it's been outside all that time so needs a bit of tlc to get it back to black.
I had a new hood fitted at Car hood warehouse In Chessington and when green mould appeared on leading edge of roof, spoke to them and they said use soft nailbrush and soap (used dilute fairy liquid) and it cleaned up nicely
Stock2k
11-03-2010 07:04 PM
