Spark plug cover looked ill...
Had a go at brightening up the lettering this afternoon with some metal polish which was useless...
http://www.s2000.pwp.blueyonder.co.uk/spc1.jpg http://www.s2000.pwp.blueyonder.co.uk/spc2.jpg So out came the Dremel and some fine grade wet and dry, much better... :) http://www.s2000.pwp.blueyonder.co.uk/spc3.jpg http://www.s2000.pwp.blueyonder.co.uk/spc4.jpg :thumbup: |
:cool:
Nice and shiney. |
Nice - what did you use on the dremel?
Firstly the 'ring of sandpaper' bit to remove the milling lines from the lettering, then I used grade 400 and 600 wet and dry on a block of wood to even everything out, then used grade 3000, 4000 and 6000 wet and dry on a foam block, finished off with a soapy wash then some meggys metal polish on one of those small hard fluffy white discs, the 1 inch diameter ones.
Top work :thumbup:
Thats the problem with Aluminium parts like that, they never stay looking good. Had you looked at sticking some varnish or something over it to stop it corroding again??
I binned mine (in the cupboard anyway) and made a CF one so it couldn't corrode. :D http://i7.photobucket.com/albums/y27...4/IMG_2728.jpg |
very nice, I have also been thinking about doing this :thumbup:
