Spoon Air Duct
Spoon Air Duct
Does any1 have this installed on their S?
looking to import one from japan but not sure if its worth the wait and the price...
any suggestions and advice?
its a quallity peice, looks good but dont expect any increase in engine output
not 100% but is it the spoon one that requires the underside of the bonnet cutting?
tHanks. yeah, jsut this one
http://www.nengun.com/spoon/carbon-air-duct
found some replica's too which im interested in- will save myself £100-£200...
I had a fake spoon snorkel for most of my ownership and I do feel that it solved a heatsoak problems. I had a spoon yellow filter at the same time.
You dont need to cut your bonnet but might need to adjust your bonnet catch/rubber stops by a mm or two. If you do it well it will look flush.
You obviously need to remove or cut your air guide. I removed mine and then got a simple CF rad cooling plate which I trimmed.
I would NEVER pay nearly £300 for it though. Get on ebay and buy a CF or Kevlar fake from HK. MUCH cheaper.
Examples..
http://cgi.ebay.com/ebaymotors/CARBON-FIBE...sQ5fAccessories
http://cgi.ebay.com/ebaymotors/HONDA-00-03...sQ5fAccessories
Be careful though there is a difference between 00-02 and 03-current. Those I posted above look to be pre 04, where a brace was fitted across the bumper which gets in the way of the snorkel. The spoon snorkel you link to looks pre 04. You will need to check it fits. I recall they made a different snorkel for 04 onwards.
Examples..
thanks nick, was just coming to that issue and i think il need to find one thats made for the 04+ bumper :/
will snoop around a while longer first before i decide so i dont get it wrong. any recommendations on any CAI systems?
The snorkel WILL FIT the facelift as I got it installed on mine, however you will need to remove the front brace (a metal bar in front of the radiator) and cut a little bit of the plastic off the grill in the bumper.
I took a ball pein hammer to the bonnet & reshaped the frame slightly, so my bonnet fits perfectly flush.
Like Nick say, heat soak IS reduced on a black car and I'd swear there is a tiny bit better response (and induction noise) at very high speeds.
Probably about slightly less effect than switching the aircon on/off so what, 2-3 BHP?
SC-SUZUKA
Member S2000 Classifieds and For Sale
06-18-2003 12:17 PM
