Steering Wheel Clicking
possible play in steering column universal joint? just throwing ideas out there, but could account for a single click when turning left or right as the slack is taken up in the joint??
A close friend (who's a mechanic) will be checking over the problem tomorrow.
I'll keep you updated.
Can steering racks fail as a result of a knock? I have no idea what a failed steering rack sounds like...There is no play in the wheel, if it wasn't for the click I'd be non the wiser.
it wouldn't fail as per say, the rack will still function but if the joint isn't tight or needs replacing you will just have a tad bit of slack hence the click (if it is indeed this causing the click) turning from one direction to the other.
Is the joint difficult to tighten and if it needs to be replaced is it costly?
Mine does it and i suspect the clock spring is what's making the noise. It's definitely not the column joint anyway, it's a plastic like sounding click from right behind the steering wheel when you gently waggle the wheel from left to right when stationary.
