Strongflex polybush kit
Has anyone used this kit on their car?? If i was to buy the kit would i be best off buying powerflex polybush compliance bushes?? Dont have the money to do the full powerflex bush kit.
Got them on all my rear,the only thing is they do not have s/steel internal tubes that's it..
Going for mugen/Honda front compliance caster bushes is a must do..
No it looks to be crap, I would definitely get the Powerflex compliance bushing instead.
The other ones are probably fine.
Going rubber on the compliance when the rest is poly, not sure if that is such a good idea?
Spherical Powerflex ?
I bought the full kit but ive only installed all the rear at the minute will get round to the front when it goes back into hiding over the winter, just make sure you grease up the bolts and metal inserts/liners well, it seems a good kit chamfered edges inside the bushes is a cross hatch pattern to hold more grease and the metal sleves inserts are too
I went for the Red kit which is not as stiff hard as the yellow kit.
