Subframe geo brackets
Hello people, does anyone know if anyone sells the actual brackets that are spot welded to the subframe that the cam adjusters work against?
Mine are in poor shape on the passenger side so i want to fix without buying a new subframe.
Cheers
Andy
Cheers
Andy
Do you mean the bit on the outside of the subframe? That's just an indicator, it's not the bit that's doing the work. If that's not what you mean, ignore me!
It's the bit where the cam actually rests against that has the two sids of it bent in to a 90 which is what the cams on the bolt work against? I will try and get a pic up tomorrow when I get home. Pretty sure I can't buy them but thought I would ask in case......I will be having some beefed up versions made
tcl
07-28-2011 06:13 PM
