Which supercharger?
I dont believe you need one. 3 bar is c40psi iirc and you wont be running that sort of boost with the std TTS kit, their race kit runs a lot more boost though
i think the stock map is fine to c20psi
If I remember correctly, the OEM MAP sensor is 2 bar, which is 1 bar negative (vacuum) and 1 bar positive (boost). But generally, sensors are designed to be accurate within a normal working range. The OEM wouldn't ever see the 13ish psi created by the SC, and 13psi is close to 1bar so getting towards the edge of its limits, and we'll away from its normal operating range. So, it might work, but you can't guarantee it's accuracy. Hence, I'd personally go for a 3-4bar map sensor.
I had a dig as i was sure the oem was ok with the TTS base kit and HKS, sos reckoned it was good to 12 psi
https://www.scienceofspeed.com/index...0-2006-09.html
and TTS quote it as needed for full race here
https://www.tts-performance.co.uk/si...ACE-All-Models
having said that it wont hurt, your tuner will know if its needed
