Supercharger custom pipework suppliers?
Hi all,
As you might have seen from some of my other posts, I'm half way through fitting a supercharger on my S. I've fitted a thicker radiator and it means some of the space that would normally be occupied by the SC pipework is reduced. I've solved the problem on the passenger side by fitting a slim AC fan, but I don't want to fit a slimmer, less effective main fan, or ideally an expensive powerful slim fan (along with the direct wiring that'll be required). Hence, I'm considering getting a slightly different intake pipe made, so I can retain the OEM fan.
Where do people generally get pipework made for SC or turbo conversions? Ideally near Bristol.
Thanks
Chris
Thanks
Chris
Thanks guys, will try them if I go that route.
