Rewiring aeromotive fuel pump
Old 02-06-2018, 09:28 AM
Barrymc's Avatar
Default Rewiring aeromotive fuel pump
Looks like I'm needing to rewire my aeromotive 340lph fuel pump.
my car is an 03 and has 1000cc deatschwerks injectors.
Needing some advise on how to rewire it, IV been told that if I'm rewiring direct to battery then I will need to get a crash sensor to cut the pump in the event of an accident.
can anyone help or point me in the correct direction.
Thanks
Old 02-06-2018, 09:44 AM
BenRNBP's Avatar
I'm assuming you're suffering from voltage drop, could you not upgrade the wiring and relay and use the existing fuel pump wiring to activate the relay ?
i.e. fit a kit like this https://www.aeromotiveinc.com/produc...mp-wiring-kit/
Old 02-06-2018, 10:28 AM
Barrymc's Avatar
Yes voltage is dropping
I suppose that is exactly what I'm looking to do.
garage were concerned about safety in event of a crash and fuel pump not switching off.
Old 02-06-2018, 10:56 AM
BenRNBP's Avatar
The built in inertia cutoff should do the job https://www.s2ki.com/forums/uk-irela...switch-940528/
Old 02-06-2018, 11:27 AM
Barrymc's Avatar
Ah superb.
that answers that.
I'll need to order the kit or rig one up.
I'll have a look at it and see what will cause me less hassle/time.
Thanks
Old 02-07-2018, 02:22 AM
flanders's Avatar
If you want to buy a kit then go for this one https://www.scienceofspeed.com/index...ring-kits.html
samsam
04-04-2019 08:43 AM
boostedap1s2
06-17-2018 09:55 PM
LordSovereign
05-27-2015 12:30 PM
Luis06s2k
Forced Induction For Sale
03-26-2011 09:11 PM
btstone84
03-29-2008 01:41 PM
Quick Reply: Rewiring aeromotive fuel pump
