To those of you running a standard air intake...
Just take the lid off, or do as I have take the lid off, push the clips up and fit the lid over them, that will give a 5mm gap all round the box, make a nice sound, and not make any heat soak worse.
I have put a Cosworth air filter in mine, but that was because it was cheaper than OEM, not because they claim power gains and better air flow.
With the induction kit on, while the changeover was definitely more audible you could also feel it more. It was definitely what I would describe as a noticeable kick felt through the chassis. I think that could be something do with the resultant power curve not being as smooth as standard as someone has mentioned above.
Removal of the box does offer some weight reduction and better access in the engine bay, but I admit with the standard box, it looks tidier, which is why I kept mine.
Keep the standard air box - it's there to hide the rusting cross-member
Mine came with a K&N FIPK from the previous owner, I'm not sure I'd have spent £250 myself though.
For same reasons as others. It works perfectly and not a hint of kangarooing.
I often wonder why anyone would want to risk a 'free-er flowing' filter! Apart from the posible effect of some geometrical influences, a 'free-er flowing' filter basically has bigger holes in the element which will allow a higher proportion of microscopically fine (and typically abrasive silica-based) dust to go into their engines. Any imperceptible short-term power gain will likely be wiped out in the longer-term by a faster general degredation of their engines internals.
The sound of the stock exhaust with 35mm bipass pipes is much nicer than the induction noise. I do take the lid off the air box occasionally but it usually goes back on within 20-30 minutes.
