Time to repair the damage
#21
#22
Managed to get a bit more done tonight and started to weld in the wing repair section,
The wing is bonded in several place's so the first job was to apply some bonding adhesive in the same place's as Honda did,
Then fit the panel into position and hold into place with grips and some big old magnets
it's now just a case of keep applying weld tacks and allowing to cool at the same checking the shut and body lines are still correct,
Then a quick grind down and a skim of bondo
the panel pulled slightly in a couple of place's with the heat from grinding that'll teach me to rush ,
i'll fill in and dress the plug welds tomorrow when the adhesive has set
#23
The problem with skilled people doing this is that it makes it look easy enough to convince idiots to have a go .... looks 'spot' on that Ray.
#24
Your skills never cease to amaze me Ray, not only a spanner genius but also a bodywork artiste
i wish all these cars were looked after like yours mate
#25
#26
But as you also said, as it will be wrapped, all it has to be is straight under the wrap. I'm with Nick on this, cars are for driving first and looking at second.
I still think the above is a dying skill - the desire and ability to have a go at something and doing more than an OK job in the process.
#28
This has never been more true. So many threads online about repair work and the level of work is so poor. Impressive stuff Dave. Will be good to see it back on the road!
#29
Some of the 'professional' repairs are also amateurish.
I would rather do what Ray's doing, than replace the entire wing, for example. There's less cutting, and cutting/welding ALWAYS allow rust in, unless you strip the shell and electro-phoretically dip it like they did at the factory.
Anyway, I take my hats off to the classic car guys - I've stolen a few images of Nick Driscoll and his Isabella coupe - talk about skill and dedication:
Personally, I'd have used it to strain the gravy and then thrown it away, since I have no panel fabrication skills and even less patience...
