Toms S2K
#232
Nice, that front and rear combo gives you pretty much identical brake bias as the stock setup.
Someone should really try to advertise these as a package deal on this forum, should be much more cost effective compared to buying from the US.
#233
Interesting use of the RX8 caliper, is this so you can retain the handbrake? Did you also look into using a two piston caliper? I've always been tempted with something like with a 350z rear caliper with an additional handbrake caliper from the likes of Willwood. Be interesting to know the weight of the RX8 calipers.
Have you gone with a completely custom disk spec or is there single piece options available?
Great work by the way. Looks very well engineered.
#234
Thanks Har-vey
Yes the RX8 unit is Nissin based like the S2000. So the handbrake actuating part/arm of the caliper is nigh on identical. Just a case of adapting the fixing of the cable to the caliper itself if that makes sense.
I wanted to keep it relatively like for like in terms of caliper performance, nothing too overpowering as to not naff up the braking bias. Just trying OEM pads for now but may well look into aftermarket pads in the future.
As for the weight of the calipers/carriers, I can find out as I've got a spare caliper.
Disc is very custom and only 2 piece as its quite shallow offset, to clear some suspension components.
Hope this helps!
Hope this helps!
#235
Thanks Har-vey
Hope this helps!
Hope this helps!
#236
#238
so your running a machined disk to accept an aluminium center? what benefit did you get from doing that? did it change the offset or were you just looking to try save weight? wouldn't it have been easier to source rotors from someone like AP?
Or have i got that completely wrong. Guess the real question is are you able to swap the disks out on this kit for a single piece disk?
#239
Spot on.
AP racing don't offer a disc in these dimensions sadly, I wanted AP discs to match the front uns, luckily mateys gaff can machine them with the same groove pattern
As for the last question, I'd need to take the disc off and take some measurements, sadly not in a position to do so at the moment. Only trouble I can think with going for a single piece setup, unless you're 100% confident/have the machinery with drilling some new wheel stud holes and centre bore. There isn't a great deal of choice with 5x114.3 PCD, 64mm Centre bore size and 20mm in disc thickness.
