Top up oil - UK
#22
I was pained by the drop height when the dealer closed the bonnet
#23
Ian's right, the drop height is preferable to pressing on the bonnet! As Paul says it's a pretty simple adjustment anyway that no-one should be worried about tackling IMO
#25
Having once had a bonnet wrap itself round the windscreen
#27
With regards to oil , Temple Garage of Harlow advised that Castrol Magnatec is the oil to use , initially the one for basic engines . They use this in all VTEC engines . I should'nt worry to much about the viscosty 10-30 as this is less important and a 10-40 will retain its effectivness over a wider temp range , As is commom with most manufacturers the spec suggested is a minimum requirement not an absolute !
One should drop close all Hoods/Bonnets steel or ali as to push close can easily lead to what is known as "PAW" prints or minute dents from finger tips or palms
coolmeister
09-27-2002 05:54 AM
