Track Pad Longevity
#31
I have the accord calipers in my garage. If I remember correctly the pads would not fit evenly in the carriers so you need a 3mm between the hub and disc so that it sits central. Might fit them but can't see it making a huge difference the disc will still be red hot
PM coming your way.
#32
Im planning on keeping them as my standard calipers are pretty much dead from all the trackdays i have done so i will probably fit them over the winter. I need to find someone who can knock up a spacer first thou.
The issue if i remember from the endless posts i read online is that when the pads have worn past a certain point then there is the chance they can drop out of the carrier. This post explains it better
https://www.s2ki.com/s2000/topic/747...calipers-swap/
#33
If you use the correct disks I don't see it being a problem.
I've not looked at too many posts but I imagine the disk needs spacing out approximately 6mm if you want to use the accord disk, which I do as it is thicker, coupled with the accord calipers and accord pads there shouldn't be a problem with the pads falling out.
Once my calipers arrive I will look into the spacers, if I have to get some made I will post it up in here and see if I can sort everyone else out at the same time.
#34
#36
I think its because the accord uses larger brake pads so they last longer.
I can dig out the part number i used to order my calipers from rockauto.com if you want. They came fully refurbished and they were pretty cheap considering.
So what disc are you planning to use? i thought the only discs you could use with this caliper set up was the ones from racing brake at huge cost or use the standard s2000 ones with a spacer.
#37
Just seen you looking for the two pot calipers, i think i might of crossed wires with you abit, im on about the larger accord caliper with single piston and larger pad. Looks like your on about a different upgrade
dls91
12-23-2016 08:21 AM
XxMerlinxX
11-29-2014 05:04 AM
