Track S2000
many non oem pistons with H22 wrist pin size at a guess maybe smaller ?.
Does a wet Darton have more rebores if needed maybe? why dry kit ?
expansion issues with dry Darton?
what charge setup did you run?
The TTS lower mount kit with 8 rib belt sounds pretty solid. I know it’s going to get hot but with a large front mount air cooler and oil cooler this should keep it stable?
[left]Still not sure on pistons and rods yet, have a lot of research to do. Engine internals is new to me. I have help building it from professionals but choosing the parts is on me
[left]A machine shop I been chatting with has tried to push me towards wet sleeves for that reason. I may yet go for them, I don’t have a huge engine budget, but I will be weighing it all up after researching over the next few months, want to get it rite first time. Another reason why I’m back on S2KI
Went into as you,
i got another engine,with low miles from an 05my
with looking at your oem bores , you can see why.
Still not certain yet, I’m enjoying the car as it is, but feel like it just needs a little more go. Hoping the new engine will give me what I’m looking for. Plus I still have to try changing the rear diff ratio as heard this makes a huge improvement to acceleration.
I've chatted to a few SC owners.. temps is a challenge. Cynic ran a lot of cooling mods on his, that was probably the best setup
UK Moderator
The diff ratio does make a difference at very low speeds, but can actually make you slower in certain scenarios where it results in more gear changes.
For example, 60-80 with short gears is quicker than with long gears, but 60-90 is slower as a) you need an extra gear change, and b) you're using a longer ratio for the 80-90 part, which makes it slower there.
This is a fun thread: https://www.s2ki.com/forums/uk-irela...rives-1023892/
And some real world experiences wit different FDs https://www.s2ki.com/forums/uk-irela.../#post22564271
burnsey (06-28-2018)
har-vey (06-29-2018)
[noodels]
Don't think the full message has been posted, but I am assuming your asking how are the scores there?
The engine I am rebuilding spun a bearing and there were bits of it everywhere in the bottom end, the oil pump filter caught the most of it. A little damage may have been done from that. The scoring is not as bad as the picture makes out, however finger nail is catching so I will be replacing them. I was going to get it honed and insert oversized rings, but as I already have another low mileage engine in the car, I want to go for a F24 build.
