Triple Gauge Pod
I have a triple gauge pod...but I had to give up the radio to fit it. It is a Defi DIN size. Two temps and one pressure gauge. Hides behind the flap when you don't want to show it off.
IIRC biker1 has 3 gauges - 2 in an A pod one mounted on the dash next to the pod - last pic I saw - sure he wd know if a RHD 3 pod was avail.
Defi I think.
EDIT: there you go
http://forums.s2ki.com/forums/showthread.p...highlight=a+pod
Defi I think.
EDIT: there you go
Unfortuneatly no one that I have found, and I have looked high and low, has made a triple gauge pod. There seems to be ALOT of demand for it, but no supplier. The best thing I have found is a universal side by side mount then maybe just mounting it where the drivers sunvisor is. I've seen a pic in one of the forums of a triple pillar gauge pod, but only the one.
If you find one please post where. I would still love to get my hands on one also.
Here's the link to the triple pillar pod pic.
http://www.streettuners.com/featured_tuner...000/page/4c.htm
defi 3 gauge unit. This Din unit size also does not need the Defi Link controller..which is required for the separate gauges..though this means you don't have the record/ playback function.
With the Defi DIN unit, where did you put your stereo?
I guess you could just mount it on the floor under the seat or something, kind of a hassle, but the Defi unit does look good in there!
