Tyre profile
The profile is the height of the tyre, isn't it? If it is, the radius of the tyre will drop, so you're speedometer won't be accurate (unless the speedo compensates automatically).
I think that's why the 17" wheel's tyrewall is an inch narrower than the 16" one.
Assume you mean for the fronts? In which case speedo is not a problem, but it could look bad! Will make your wheels look smaller and your arch gap bigger. Why do you want to do it?
I did want to get Ultrac Sessantas all round, but they are out of stock of the OEM front size.
Guess a 225 is out of the question too.
No matter, ill find summit else.
Thanks all.
Thanks all.
if it's as simple as 3 is twice as soft as 1.5, then yes. 5% profile change does cost.
ofcourse it might help on steering feel; stiffen up the somewhat soft front end (my goodyear eagle f1's are a touch soft)
speedo out shouldnt make a difference as the speed is taken from the gearbox and thus the rear wheels speed, and not from the front wheels. if you were changing the rolling radius of the driven wheels, then that'd be different. front wheels will just 'keep up' and will have a higher RPM as minor as it is.
your also saving a bit of unsprung mass too, so that'd help aswell
razorsharp192
02-24-2011 12:53 PM
BSM139
01-27-2005 07:01 AM
