Tyres questions again
Well, I had a look at my rears (RE050) the other day. I thought I was keeping track of their wear. Found them to be down to the wear bars :eek1: - less than 3mm in some areas. Mind you, never had any scary moments, even in pounding thunder storms. I must really be driving like my granny!
So I ordered two rears from Tirerack in the US. By the time I got them here through the sky box, cost was about TT$5,000 (UKP 382.00). Ouch :eek: The fronts are around 5mm tread depth. Should I be OK with this for a while or should I trey to change them at the same time? They look fine, but maybe they won't match the rear's grip and change the balance a bit? |
fronts will be fine for some time yet. They last longer than the rears.
Not if you drive it right, they don't!
Aged tyres on one end & new rubber at the other will do odd things to the handling. Bets replaced as a set, like Honda say in the book. |
Sorry to disagree with Nick. Yes Honda may say to replace all at the same time but with 5mm left on the fronts you should be good for a while, difference in feel will be minimal.
As Lower said the rears do last longer than the fronts, as with any rear drive car! |
Yeah! Like what he said :drunk:
:LOL:
I need to change my rears to. I'm on RE01's though so don't really have much choice but to replace all four. :rolleyes: |
Ouch! Are you going RE01's again?
Sorry, just re-read your post so I take it you are going RE050's?
I doubt very much I'll be able to get hold of any will I? I haven't really tried TBH. I was just going to get the Bridgestone recommended replacements. :)
