Undersealing and rust prevention
I'm looking at getting the car undersealed with Dinitrol (I gather it's better than Waxoyl?). Has anyone had it done or have experience with it?
Can someone recommend a reputable shop to do this for me? I'm in SE London, so somewhere close by would be ideal!
Thanks
Thanks
i had it done, its good stuff
but used JR classics in donny
you want someone who does all the cavity stuff and inside the rear arches etc
it stinks for months afterwards so hopefully not your only car
UK Moderator
I used DoctorMX-5 https://www.doctormx5.co.uk/what-we-do/rust-prevention/
Note that they've had some poor reviews of late, but check for MX-5 specialists as the cars are similar to ours but rust even more!
Oooh I been thinking about getting this done on my '08 - This JR classics - they did a proper job? not just covering over everything? I saw a couple of threads on here and got put off as it looked like a minefield finding somewhere that knew the proper way to do it and i don't really know how to ask for what is right!
i had a boot leak from washing the car ironically which meant the boot pan rotted so a new one will be going in, start of march.. i may have some pics, will have a dig
Thanks for the responses!
I've booked in at themx5restorer.co.uk for the end of this month after a recommendation from a friend who bought his mx5 from them.
I'll try and get them to take some photos and feedback here once it's done!
how did it go if you don’t mind me asking! Good job?
I'm doing this myself. Going a bit overboard but hopefully will keep the car alive longer.
I'm going for:
- Remove surface rust, BH Deox Gel if required
- Por-15 Degrease
- Por-15 Metal prep
- x2 layers of Por-15
- BH Dynax s50 inside box sections
- BH Dynax UB ontop of POR for arches & underside
Time will tell how it holds up.
I'm going for:
- Por-15 Degrease
- Por-15 Metal prep
I'm going for:
- Por-15 Degrease
- Por-15 Metal prep
I'm going for:
- Por-15 Degrease
- Por-15 Metal prep
It went well but was a very lengthy process. Prep is everything so remove as much rust as possible. If using POR15 make sure to thoroughly degrease & use metal prep to etch surface. If rust is minimal I would just use BH spray on products rather than paint. I feel it was a bit overboard.
A few key areas which I found needed most attention:
- Front inner wing traps dirt which causes rust to set in on lower wing / removable panel
- Jacking points front and rear
- Engine bay cross beam (under plastic intake)
- Engine bay under battery tray (acid leak in my case)
- Rear arches behind plastic panels
- Rear arch inner lip (needed welding on driver side due to minor perforation)
- Behind rear bumper, sides of boot floor
The underside was my least favourite part, painting/degreasing above my head was not enjoyable, but you could see minor corrosion setting in around spot welds so a worthy chore.
I thought I was on the home straight but pulling back the rear arches I found hairline cracks in the paint in a particular location (on both sides). A wire wheel showed rust coming in from the seam and eating inside out. Apparently this is a common area so inspect thoroughly. Gave me the chance to learn to weld!
I used about three cans of s50 & 5 cans of UB. But I did do:
- Engine bay
- Whole underside
- Entire boot
- All four arches (including inside of removable wings)
- Behind front bumper
So essentially all of the chassis that was visible, I also coated all the suspension components. One can does quite a long way
- Engine bay
- Whole underside
- Entire boot
Nottm_S2 (04-25-2020)
