Urgent rear piston advice needed
Old 02-25-2019, 11:09 AM
Daytona-Dave's Avatar
There is a chap who has a vid on you tube where he use's compressed air via a foot pump but the same would be achievable with a compressor and air gun down the pipe inlet
Old 02-25-2019, 01:58 PM
Fellblade's Avatar
I used a footpump and a tyre valve stem screwed into where the banjo bolt normally screws in. Seat the seal into the caliper body first, push the piston into it, pump the footpump and then work it around until the seal works along the outside of the piston
Old 03-08-2019, 11:57 AM
Oilslick's Avatar
Originally Posted by chrispayze
Other option is to use a ring of plastic (old folder or something) to make a sort of 'cone' to help ease the piston into the seals. Push the piston into the ring of plastic (which is holding the dust boot open) then remove the plastic. It is a faff, but doable. I agree with the others though Having done it once, I wouldn't bother again. And I DIY everything!
new dust seals arrived today (after ripping my previous two) - after taking inspiration from the above I used a plastic document wallet and cut into a strip, wrapped into a sleeve and.... got it done in about 30secs.
Soooo easy doing it this way.
Therefore thanks for the advice!!!
Old 03-09-2019, 02:21 AM
martin j's Avatar
A bit like a piston ring compression clamp?
Old 03-09-2019, 07:18 AM
Oilslick's Avatar
Calipers are rebuilt and back on the car. But now the abs light is on constantly. Anyone got any ideas?
Old 03-09-2019, 07:28 AM
flanders's Avatar
Tried driving it? It usually takes a few hundred meters for it to turn off.
Old 03-10-2019, 10:47 AM
Oilslick's Avatar
took it for a 10min drive and light still on. Tested to see if was working and kept locking the front driver side wheel. So there’s def a problem. My OBD2 doesn’t find anything, needs an mot and service soon - so guess I’m going to have too let Honda find the fault for me.
Old 03-10-2019, 11:07 PM
flanders's Avatar
You could check the ohm readings from the sensors and compare to see if anyone seems bad.
If you spin the wheel in the air you should also get a small voltage reading.
Check this link for pin outs (hopefully the same on RHD cars) https://www.s2ki.com/forums/s2000-un.../#post24563726
s2000maniac
03-02-2014 09:27 PM
erikvanden
09-09-2011 12:44 PM
Moddiction
07-28-2011 09:55 AM
jswisc
04-01-2010 06:52 AM
pli
10-31-2008 02:23 PM
Quick Reply: Urgent rear piston advice needed
