Vented bonnet and respray questions
Evening all
I have a set of AT throttles bolted to side of my engine and could do with a vented bonnet to help with Temps, which would be the best option bearing in mind our inclement weather?
I'm also getting the car sprayed as it's battered, now I could stick to Silverstone and be happy or go for a colour change.
The problem with the latter is I can't be arsed stripping everything to do it right,so just wondering what people's opinions are on having an engine bay a different colour to the rest of car?
Cheers!
Cheers!
If you're looking to sell, different colours could affect resale. If you're keeping it, it's completely up to you. If it were me, I could put up with silver/grey engine bay as it doesn't scream 'not supposed to be like this'. If it were red and you sprayed it blue or yellow, for example, it would be hideous.
Hi
there is a previous vented bonnet thread somewhere on here.
I have a mugen CF rep which is good fitment, can be purchased for around 500 to 600 quid. If your lucky you can get rain screens for the vented parts which will prevent you sucking in water along with small children.
Alternatively consider cutting the OEM bonnet and fitting some mesh, looks good too.
Personally I couldn't give too hoots which shade of resale grey my car is (if it were to be resale grey).
If you have OCD or are particularly anal retentive I would save yes get it all sprayed up including all cuts, but if not why bother. just do what people can see.
Mike
Mike
Member
The best way to reduce temps with ITBs without a plenum intake is probably a NACA duct just above them, and have a bonnet with the large vent at the front to extract radiator heat.... And wrap your manifold.
This is close to perfect. Also comes with rain blanks. Downside is that it's $6000
I've a Spoon vented bonnet to rid the bay of some additional engine heat from the charger, and it's a PITA. I does noticeable reduce heat over stock but any rain pours straight onto the air filter and some of the electrics around the radiator.
I'm not sure there are rain thingies like the Mugen, which are very cool.
Proper color change requires taking the car apart. Otherwise the car looks like the other word for poop.
If you have a "matching numbers" hood/bonnet leave it alone or pick up one from another car andbugger modify it. One or two degrees of temperature at the intake isn't worth bothering with (even if it's Centigrade). Vented hood will help with heat soak if your intake is under there but it's easier to move the air intake outside.
Now that someone mentioned it I've no clue how a buddy washes his car with the hood vents there. These just trace the inner hood reinforcement panel. I'm sure the original owner thought this was a good idea for a turbo-charged car.
-- Chuck
-- Chuck
I have a J's style hood and i plan to rid of it and do the above. The vent is right over the filter now its turbo charged so i had to make a rain screen out of a pasta packet for now...
Just to add - the noise with an FIPK was nuts with a vented hood
