Vibration under load
I see you have already done your drive shaft cups swap. Is there a noise associated with the vibrations? Wheels bearing or could be diff related. The prop has a little movement on it, so should damp vibrations from the engine.
You can check engine mounts etc from this post: https://www.s2ki.com/forums/s2000-un.../#post23032920
Does the engine idle ok?
Idles fine, and revving the engine in neutral doesn't cause any vibration. It certainly 'feels' like the source of the vibration is behind me, and I've already replaced diff mounts.
Its hard to pick out a source noise over the noise of the cabin being vibrated, but I think there is a 'wup wup wup wup' noise associated with the vibration, buts its hard to discern.
