Washer jet issue
Washer jet issue
Drivers side.
Took it out back to the Y tube, short length is fine, spilt the jet from the 90 bend and what turns out is a rudimental non return piece?
Freed the ball bearing as it was jammed solid and can feel it 'breathing through' when I blow on it, with the ball bearing at either end now.
Bearing occasionally jams, is that fine as it still blows...?
anyhow putting it back together I take it the arrow on the non return piece needs to point to the jets...didn't see it until I had it in bits...
Me too
Honda even do them cheap. Or use a bit of brake pipe .
The little metal O rings in the One Way Values degrade over time. I replaced both, jobs a good un!
Parts PFKL562640 - VALVE, ONE WAY (MITSUBA)
https://www.lingshondaparts.com/hond...0&block_05=hcr
Anything in particular to ask for? Or just washer jet non return valve :-)
