Stock ride height coilovers
Old 02-20-2018, 04:37 AM
R5HKK's Avatar
Default Stock ride height coilovers
Does anyone know of midrange coilovers that can keep stock ride height. My suspension bushes are seized in the right geometry, and I use my car for work which includes shocking roads and lots of big speed bumps. The s2k has done 110k so original suspension is horrible
Thanks
Old 02-20-2018, 06:23 AM
nomadicS2k's Avatar
Most should be adjustable to OEM height - searching suggests that BC Racing can be..what is your budget?
Old 02-20-2018, 09:27 AM
chrispayze's Avatar
Meister R will all go to oem height. That's the reason I I went for their GT1s instead of KWs.
Old 02-20-2018, 11:29 AM
R5HKK's Avatar
If I can stay at stock height then budget would be around 800 ideally. The car is driven through winter so corrosion resistance is important to me.
​​​A quick search showed corrosion can be an issue with some hence the concern. Thanks for the answers btw
Old 02-20-2018, 11:38 AM
chrispayze's Avatar
My Meister Zeta Rs lived outside for years and were still in good nick.
Old 02-21-2018, 05:18 AM
CynicG's Avatar
How about getting another younger set of OEM? A lot cheaper I would think and plenty about as people add coilovers. I grabbed a 40k set for future use just in case.
Old 02-21-2018, 06:41 AM
R5HKK's Avatar
Cynic g, I wouldn't mind that but I don't see many come up, seems to be mostly high milers
Old 02-21-2018, 11:44 AM
CynicG's Avatar
Try a WTB post in For Sale section. I bet a few people have then sitting around. In fact, you could probably take mine as my car will never go back to standard now. PM me!
Old 02-22-2018, 01:02 AM
Irish TuneR's Avatar
I got a set of low mileage OEM and theres a slight knock after 10k use, used with new Spoon springs when installed. Given the springs are made to be used with OEM id recommend new as used will go, its just a lottery on when.
Old 02-25-2018, 12:04 PM
R5HKK's Avatar
Any idea if bilstein b14 will be able to maintain close to stock height? I've heard these are excellent midrange shocks.
Thanks
Quick Reply: Stock ride height coilovers
