Wheel Bearings
Wheel Bearings
Hello Guys
Im putting some extended wheel studs on so need to replace the hub bearings. Bit of a shame really as the originals are still in pretty good condition.
I ve looked around and they seem very expensive. The honda parts are £80 each and eBay copies are still £52 !
Can someone point me in the direction of some cheaper ones please?
raz
Rob as far as I know reused bearings don't last so long after you remove and refit the hub assembly. Though I personally have no experience in this department thats just from what I have read on here.
Plus whilst its all apart its a nice thing to do.
Are you saying you have to remove the hub to remove the studs?
No way, I reckon you can just hammer them out and hammer the new ones in.
ATEOTD, studs are prone to snapping so i cannot believe that you have to remove the hub to remove a stud.
You certainly don't have to on a Civic/Integra and Honda won't redeisgn for the sake of it
Thanks for the replies guys.
Can someone point me to the best place to buy these bearings. I am gutted about how expensive this is going to be. It is eating into the APR fund.
Just as an aside, how do you know if a bearing has gone? If I load up my front drivers wheel on a hard left turn I hear a clicking. It's not from the back wheel and is silent at all other times. Is this the beginning of the bearing failing?
I needed a new rear bearing not long back.
In the end I got it from the main dealer.
I found the same ebay one as you and also found a company that offered some for £75.
I decided that the ebay one seemed a bit too budget and the £75 was too close to OEM price to not go OEM.
As the bearings are such key elements of the car I decided not to skimp.
I also agree that once the hubs been removed the bearing has a good chance of being knackered. I was told that by a mechanic and had it happen to me.
I presume it's something to do with the bearing having a bit of an internal shuffle when the driveshaft is removed – but that's a total guess.
