Where to feed cable through firewall
As title, I'm looking to take a feed direct from the battery into the cabin. I know there is a grommet with cables on the driver side of the engine bay, is there one on the passenger side behind the battery? I've only found reference to LHD cars where the aforementioned firewall cable route and battery are next to one another, so layout seems to be different.
UK Moderator
There is one on the passenger side behind the battery. If you like I can try to take a photo later but essentially it's in the same place as the LHD "driver's" side hole.
If you only need small power for gauges and stuff, there is a feed on the fuse box via spades with constant 12v and ignition 12v as well as dimmer control.
Sent from my GT-I9300 using Tapatalk
I currently have a few devices running off the ignition spade under the wheel. I'm planning on finally adding the waeco heated seat kit and wanted to make the wiring a little more fit for purpose, so will wire in a fuse box for the accessories.
I think the bus bar in the fuse box ought to be man enough for that.
Here's a guide you might find of use:Tidying a Scion FRS
Jstone_ap2
11-09-2013 09:53 PM
