Will an OEM exhaust fit in an S2000?
Old 02-08-2011, 11:49 PM
GaryB's Avatar
Default Will an OEM exhaust fit in an S2000?
My new exhaust should be arriving shortly (Thanks Hendy ).
My question is, if I take it somewhere to be fitted, will I be able to stuff the old system into the car to get it home?
I want to keep it in case I need to swap back for some reason.
Old 02-08-2011, 11:51 PM
UK Moderator
BSM139's Avatar
IIRC the OEM is a single piece, so will probably need a large estate/hatchback, or a small van to transport it.
Bharat
Old 02-08-2011, 11:55 PM
nomadicS2k's Avatar
You can try, by putting the cat end in the foot well. And you would need to wrap it...
I doubt it will fit!
Old 02-09-2011, 12:01 AM
GaryB's Avatar
Bum!
Thanks chaps.
Old 02-09-2011, 12:02 AM
eSeM's Avatar
I once saw an OEM exhaust being fitted into a Ford Fiesta and a I managed to get one int a CTR but it was very tight.
Old 02-09-2011, 12:13 AM
Zudzilla's Avatar
OEM exhaust is all 1 piece. Its Huuuge and heavy. definitley won't fit in your car.
Old 02-09-2011, 12:21 AM
GaryB's Avatar
OK cool. That's plan B then.
Cheers.
Old 02-09-2011, 12:31 AM
j8mie's Avatar
No way will this fit in the car. The weight alone means you stand a very good chance of getting cracked in the head by one of the rear cans as you drive along.
Old 02-09-2011, 12:56 AM
UK Trader
Si@Hendy Performance's Avatar
It wont fit! I had trouble fitting it intp my wifes old DC5 when it was fitted Gary!
Old 02-09-2011, 01:36 AM
MB
Member
MB's Avatar
I've seen someone do it on here, but there's no way on earth I would try it.
Your interior would get damaged for one.
Quick Reply: Will an OEM exhaust fit in an S2000?
