Winter refresh, Engine, Seats harness etc ready for next season
Old 10-31-2018, 06:11 AM
Daytona-Dave's Avatar
Originally Posted by Nottm_S2
900 is a fair bit, how many before you relax?
good work Ray!
i'm planning on doing my valve clearances and shitting it about that haha. i'd prefer to bring it to you but needs to be stone cold doesnt it?
No that's an urban myth, the engine has to be below 38dec as per the Honda workshop manual, depending on what country you are in would have a bearing on what stone cold is so if someone in Florida or Spain in the middle of summer has to set the tappets then stone cold wouldn't mean much hence the threshold being 38dec, i have checked and anything from there down to 10dec has no bearing on gap
Old 10-31-2018, 09:53 AM
Nottm_S2's Avatar
just the inlet ones that crack so you need 8 of the upgraded ones?
Cox have an offer on atm
https://www.coxmotorparts.co.uk/hond...r-upgrade-kit/
i have a load of parts waiting to put on mine so have held off on this.. to date .. if i got to yours early it would cool down enough in an hour or two you reckon?
Old 10-31-2018, 01:51 PM
Fellblade's Avatar
Nottm_S2, I've got the bent / offset feeler gauges required for the job plus the valve adjustment tool etc and have done mine a couple of times now, so if it's not feasible to take to Congleton and get it looked at I can always drop by and give you a hand / tooling given I'm in the area.
Old 10-31-2018, 10:49 PM
mtunreal's Avatar
That's a really good price. Only a few more quid than I paid for them direct from Japan.
Old 11-02-2018, 02:22 PM
Old and new uprated retainers
[/url]
Oil squirter bolts, most on here will know the upgrade, it seems mine was missed as it still had the 2 hole bolts so a new set of 4 hole bolts will be going in when i get around to rebuilding it,
Old 11-02-2018, 03:53 PM
ValveBounce's Avatar
Another great thread from Daytona Dave!
Keep up the good work.
Old 11-03-2018, 02:40 PM
noodels's Avatar
Retainers have so much more land in them !!
Old 11-04-2018, 02:03 AM
Nick Graves's Avatar
Those bores do look amazing.
Those retainers do look worrying.
Especially since my first engine went under very similar circumstances to Lower's.
Old 11-13-2018, 01:02 PM
Piston ring check today,
First up top ring, wear limit is 0.60mm this came in at 0.43
second ring, wear limit is 0.90mm this came in at 0.84
oil control ring, wear limit is 0.80mm this came in at 0.92
so as in the other 3 engines i stripped to build the one for my other s the compression rings are in spec and the scrapper rings and outside spec so the engine would have had good compression but burn rather a lot of oil, a new set of piston rings is sat on the bench waiting to be fitted ,
Old 11-13-2018, 01:38 PM
Nottm_S2's Avatar
love the attention to detail Ray. when you swap rings does it need running in before you go off racing with it?
Quick Reply: Winter refresh, Engine, Seats harness etc ready for next season
