Go Back  S2KI Honda S2000 Forums > International Communities > UK & Ireland S2000 Community
Reload this Page >
Winter refresh, Engine, Seats harness etc ready for next season
Old 10-31-2018, 06:11 AM
Daytona-Dave's Avatar
Liked 45 Times in 33 Posts
Originally Posted by Nottm_S2 View Post
900 is a fair bit, how many before you relax?
good work Ray!
i'm planning on doing my valve clearances and shitting it about that haha. i'd prefer to bring it to you but needs to be stone cold doesnt it?
No that's an urban myth, the engine has to be below 38dec as per the Honda workshop manual, depending on what country you are in would have a bearing on what stone cold is so if someone in Florida or Spain in the middle of summer has to set the tappets then stone cold wouldn't mean much hence the threshold being 38dec, i have checked and anything from there down to 10dec has no bearing on gap
Daytona-Dave is offline
Old 10-31-2018, 09:53 AM
Nottm_S2's Avatar
Liked 56 Times in 56 Posts
just the inlet ones that crack so you need 8 of the upgraded ones?
Cox have an offer on atm
https://www.coxmotorparts.co.uk/hond...r-upgrade-kit/
i have a load of parts waiting to put on mine so have held off on this.. to date .. if i got to yours early it would cool down enough in an hour or two you reckon?
Nottm_S2 is online now
Old 10-31-2018, 01:51 PM
Liked 3 Times in 3 Posts
Nottm_S2, I've got the bent / offset feeler gauges required for the job plus the valve adjustment tool etc and have done mine a couple of times now, so if it's not feasible to take to Congleton and get it looked at I can always drop by and give you a hand / tooling given I'm in the area.
Fellblade is offline
Old 10-31-2018, 10:49 PM
mtunreal's Avatar
Liked 9 Times in 9 Posts
That's a really good price. Only a few more quid than I paid for them direct from Japan.
mtunreal is offline
Old 11-02-2018, 02:22 PM
Old and new uprated retainers
[/url]
Oil squirter bolts, most on here will know the upgrade, it seems mine was missed as it still had the 2 hole bolts so a new set of 4 hole bolts will be going in when i get around to rebuilding it,
Old 11-02-2018, 03:53 PM
Liked 6 Times in 5 Posts
Another great thread from Daytona Dave!
Keep up the good work.
ValveBounce is offline
Old 11-03-2018, 02:40 PM
noodels's Avatar
Liked 57 Times in 56 Posts
Retainers have so much more land in them !!
noodels is offline
Old 11-04-2018, 02:03 AM
Nick Graves's Avatar
Liked 19 Times in 19 Posts
Those bores do look amazing.
Those retainers do look worrying.
Especially since my first engine went under very similar circumstances to Lower's.
Nick Graves is online now
Old 11-13-2018, 01:02 PM
Piston ring check today,
First up top ring, wear limit is 0.60mm this came in at 0.43
second ring, wear limit is 0.90mm this came in at 0.84
oil control ring, wear limit is 0.80mm this came in at 0.92
so as in the other 3 engines i stripped to build the one for my other s the compression rings are in spec and the scrapper rings and outside spec so the engine would have had good compression but burn rather a lot of oil, a new set of piston rings is sat on the bench waiting to be fitted ,
Old 11-13-2018, 01:38 PM
Nottm_S2's Avatar
love the attention to detail Ray. when you swap rings does it need running in before you go off racing with it?
Quick Reply: Winter refresh, Engine, Seats harness etc ready for next season
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
