Winter refresh, Engine, Seats harness etc ready for next season
#32
Oil pump stripped and inspected, all in perfect condition and within new spec, new timing chain and oil pump chain fitted plus baffled sump, now on to the time consuming head clean up and valve lapping
old and new chain next to each other
#33
Cylinder head, this probably consumes more labour than anything else, first off is to strip out all the valves then check for level and damage after this the combustion chambers and valves need decoking and cleaning, engines don't suffer the same as they did years back but it's important to remove all trace's as the coke deposits retain heat and cause hot spots especially around the exhaust valve area this can cause pre-ignition and cause problems for your tuner, after this the head surface needs cleaning down with a flat block and wet fine rubbing paper, then comes the laborious task of hand lapping in all the valves to get a nice grey ring around the valve face and seat and all pits and marks have being removed to create the best seal possible,
#35
Good time to check plug hole thread condition for damage & wear.
#37
#38
Head back on so last set of pics before startup tomorrow (Sat) if all goes to plan, going to fit the cams in and set the rocker gaps tonight then a once over in the morning and wang it over without the plugs to get the oil up then cross everything and hope for the best
