Yet More Water Leaks in Boot - lol - Through Antenna
Hi Guys,
Yet more water leaking woes. lol. Would seem s2000 ownership is all about water ingress issues. haha! This time is seems to be coming through the radio antenna. Is this another common issue? Any solution to this or is it just a matter of buying new seals? Items 7, 8 and 6 Or have people been adding silicon sealant instead? I assume item 6 will perish overtime as it is always exposed to the sun, and cats or foxes will chew the antenna and weaken the seal. From looking at the fastening nut (item 7) I would need some sort of circlip pliers to unscrew it? https://cimg6.ibsrv.net/gimg/www.s2k...7f79709426.jpg Thanks again guys |
There is a special 'antenna tool'.
But I shocked it loose with a hammer & screwdriver and used a bike spanner. It probably merely requires tightening, & the seals cleaning & treating with silicone & rubber lubricant. Unless the hole in the wing is rotted. |
Thanks Nick, I'll disassemble it and see what lurks beneath.
Your probably right. Might just need cleaning and lubricating with shin entsui grease. Don't think its costs that much for the seal, will get some quotes. |
Did you cure this leak?
Ahh Yes, forgot to update the thread.
As Nick mentioned, I stripped the antenna and its seals down and cleaned and lubricated the seals with shin entsui grease and re-assembled. To be honest I think it was actually a loose fastener nut (item 7) and just needed tightening. Was a good exercise to strip it down though. So far so good, no more water ingress :) |
Originally Posted by s2000_f20
(Post 24559889)
Originally Posted by frenchy
(Post 24560744)
Any tips on tightening the nut?
I used a watch back case remover like this, its adjustable so can fit the fastener slots perfectly.
https://cimg6.ibsrv.net/gimg/www.s2k...74c03791ee.jpg Can be bought quite cheaply on ebay, the slot pieces does look quite different in this link. Pretty sure you could find an identical one if you spent alittle time looking around online. https://www.ebay.co.uk/itm/Watch-Back-Case-Cover-Opener-Adjustable-Remover-Repair-Wrench-Watchmaker-Tool/401694094092?_trkparms=aid%3D222007%26algo%3DSIM.M BE%26ao%3D1%26asc%3D20140122125356%26meid%3D2c9530 7f3f4240f392923aa322b16ab8%26pid%3D100005%26rk%3D1 1%26rkt%3D12%26sd%3D273326687501%26itm%3D401694094 092&_trksid=p2047675.c100005.m1851 Havent got any torque specs, but you will know when to stop once you tighten the fastener down. |
