HKS S2000 Supercharger Kits in Stock
We have a limited number of HKS S2000 Supercharger kits in stock and available at a special price to all. £3699 Delivered
Delivery to anywhere in the UK or mainland Europe included!!
CALL or EMAIL me at rob@sumopower.com for yours today
Code No. 12001-AH006
With F1 level piston speed and super high rpm characteristics, the S2000 is a great representation of Japanese sports cars. This kit has been designed to try and compliment these characteristics and deliver more power as the engine rpm increases creating a forced induction system that those who love Honda engines will agree with.
Smooth torque delivery leads to ease of use which makes the HKS GT Supercharger a great match for the engine. We would like those who want more power but feel resistance to forced induction on a Honda to experience this setup which has acceleration feel reminiscent of a tuned NA engine
* φ58 restrictor included in the GT S/C Pro kit is for US specification vehicles and may cause damage to Japanese specification cars. Please adjust restrictor size to approximately φ40 for 300ps output. Test vehicle used φ44 restrictor included with fuel upgrade kit.
(sold separate)○ 14007-AH001○ 14007-AH002Control
(sold separate)× Need such as F-CON iS for setting.○ FLASH EDITOR
/42015-AH001*RemarkIf you are not using with Fuel Upgrade Kit, you need to make a restrictor.If you are not using with Fuel Upgrade Kit, you need to make a restrictor and Flash Editor setting. VehicleModelEngineModel YearS/C SIZECode No.PriceRemarksS2000AP1F20C99/04-05/10GTS704012001-AH006
GTS7040 Pro Kit/Fuel Upgrade Kit for S2000
【GT SUPERCHARGER Pro KIT】
S/C Unit, S/C Oil Parts, S/C Fitting Parts, S/C unit Pulley, Belt, Suction Pipe, Intercooler, Intercooler Pipe (Includes relief valve)* GTSC Pro Kit requires a separate engine control system in order to operate correctly* φ58 restrictor included in the GT S/C Pro kit is for US specification vehicles and may cause damage to Japanese specification cars. Please adjust restrictor size to approximately φ40 for 300ps output. Test vehicle used φ44 restrictor included with fuel upgrade kit.
【FUEL UPGRADE KIT】
- With GT S/C Pro Kit you can have more than 300ps and 30kgf・m.
PARTS
Large Volume Fuel Pump, Large Volume Injector, Restrictor(φ44)【FLASH EDITOR】
The data is pre-installed for Flash Editor for AP2 if used GT Supercharger kit and Fuel Upgrade kit together. It's very reasonable and easy to install. (More information available of Flash Editor in the website)【Comparison】
【Characteristic】
【Notes for Installation】
- Kit does not have control device, you need separate device.
- Injector (Stock injector volume is insufficient to bring out full supercharger performance)
- Spark Plug: HKS Super Fire Racing M45i or higher
- Engine oil with high temp grade of over 40 should be used
- Clutch should be changed to one of higher torque capacity
- When fitting front mount intercooler, The stock air guide and under cover require small modification for pipe clearance.
* If using HKS Flash Editor S/C data: HKS Fuel upgrade kit must also be fitted
FUEL UPGRADE KIT
VehicleModelEngineModel YearCode No.PriceRemarksS2000AP2F22C05/11-07/914007-AH002for GT S/C KITAP1F20C99/4-05/1014007-AH001for GT S/C KITFLASH EDITOR
VehicleModelEngineModel YearCode No.PriceRemarksS2000AP2F22C05/11-07/942015-AH001¥60,000For fuel upgrade kit installed vehicles●Fuel & Control device setting
AP1AP2GT SUPERCHARGER○ 12001-AH006○ 12001-AH006Fuel Upgrade Kit(sold separate)○ 14007-AH001○ 14007-AH002Control
Anees
12-24-2018 04:04 PM
EvasiveMotorsports
43
06-04-2015 10:57 AM
RavSpec
02-18-2015 05:30 AM
