Okada Project Direct Ignition coilpack
Hi all,
We are now Okada Project dealer and we would like to kick this off with a group buy.
Here is some info -
PLASMA DIRECT (PAT)
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car.
Highlights
・100% secondary current (Spark Amperage) increase
・4 Times Spark Energy Increase for the initial spark discharge
・Easy installation. Only replace stock coils to Plasma Direct.
・Compatible with all OEM components
・Compatible with OBD-II (On-Board-Diagnostics)
Here is the dyno result you can see 8BHP gain specially at the top end by just swapping the coil pack with 7psi low boost and 13BHP gain with 9psi higher boost
http://www.okadaprojects.com/usa/dyn...da%20s2000.pdf
Direct replacement coilpack, just plug and play and you can feel the different right away -
Retail on this is - £685 inc VAT. We are now doing a group buy price for just £620 inc VAT shipped.
Group buy will close next Wednesday 1st August and we should have the coil pack here 7 days after group buy close.
Thanks
Dixon@DMS
Please put your name down if interested -
1. Dixon x 2
2.
3.
4.
5.
Here is some info -
PLASMA DIRECT (PAT)
Highlights
Thanks
Dixon@DMS
1. Dixon x 2
2.
3.
4.
5.
Hi all,
Here is some info -
PLASMA DIRECT (PAT)
Highlights
Thanks
Dixon@DMS
1. Dixon x 2
2. akane12sl
3.
4.
5.
Here is some info -
PLASMA DIRECT (PAT)
Highlights
Thanks
Dixon@DMS
1. Dixon x 2
2. akane12sl
3.
4.
5.
