Spoon Sports
Banned
Spoon Sports
Spoon Sports products brought to you by Spoon Sports Europe
On to the parts - Listed in website category order
Suspension System
Damper Kit Full Spec
Damper Kit Fixed Type
Spoon Progressive Springs
Steering Rack Rigid Bush Kit
Front Upper Arm Gusset Plate
Rear Control Arm Set
Offset Ball Joint Assembly
Zero Bump Steer Kit
Suspension Bush Set
All bushes also sold separately
Bush Set Rear Control Arm
Bush Set Rear Lower Arm
Lower Damper Bush
Front Compliance Bush
Bush Set Front Lower Arm
Bush Set Front / Rear Upper Arm
Body Reinforcement
Strut Tower Bar Front
Front Cross Beam Bar
Rear Cross Beam Bar
Transmission Tunnel Brace
4pt Roll Cage
7pt Roll Cage
Subframe Rigid Collar Kit
Brake System
Spoon Monoblock Calipers
Brake Rotor Front
Brake Rotor Rear
Brake Pad Front
Brake Pad Rear
Brake Hoses
Brake Pedal Box
Spoon Sports Europe are the Spoon Sports authorised distributor for Europe. This can be varified on the Spoon Sports Japan website - Spoon Jp Authorised Dealers
Whilst we are the only Authorised Distributor in Europe we have our own dealer network. Each Authorised dealer or trader can be checked on our website SSE Authorised Dealers
Why buy from us or one of our authorised dealers?Whilst we are the only Authorised Distributor in Europe we have our own dealer network. Each Authorised dealer or trader can be checked on our website SSE Authorised Dealers
Firstly and for mostly stock. We are carrying over £150,000 worth of stock. We air freight stock replenishments from Japan monthly meaning you will receive your parts in a reasonable time-scale.
Secondly warranty. Any products purchased through the authorised dealer network will be supported and warranted. Whist all Spoon products are built to excellent quality occasionally something might go wrong.
Any Spoon products purchased from non authorised dealers will not be warranted.
Lastly, authentic, genuine products. unfortunately whist we do what we can to prevent it the market is flooded with replicas and copies. We guarantee that if it has been supplied by us it is Genuine and Authentic made in Japan Spoon Sports produce.
================================================== ===============================Secondly warranty. Any products purchased through the authorised dealer network will be supported and warranted. Whist all Spoon products are built to excellent quality occasionally something might go wrong.
Suspension System
Zero Bump Steer Kit
Suspension Bush Set
Lower Damper Bush
Body Reinforcement
Rear Cross Beam Bar
4pt Roll Cage
7pt Roll Cage
Brake System
Brake Rotor Front
Brake Rotor Rear
Brake Pad Front
Brake Pad Rear
Brake Hoses
Brake Pedal Box
Banned
Intake & Exhaust
Spoon N1 Cat Back
421 Manifold
Venturi Big Throttle Body
Venturi Big Throttle Body DBW
Air Filter
Carbon Air Duct
Power Unit
Complete Engine F20 2.0
Complete Engine F20 2.2
Complete Engine F22 2.2
F20C Short Block 2.0
F20C Short Block 2.2
F22C Short Block 2.2
F20 2.2 Stoker Kit
Oversize Piston Kit F20
Oversize Piston Kit F22
Spoon High Lift Ex Camshaft
Spoon High Lift In Camshaft
Spoon Thin Head Gasket
AP1 Yellow Head Cover
AP2 Yellow Head Cover
Carbon Kevlar Plug Cover
Baffled Sump
Aircon Delete Belt
Engine Transmission Mount Set
Engine Mount Ring
Engine Oil Filler Cap
Spoon N1 Cat Back
421 Manifold
Air Filter
Carbon Air Duct
Power Unit
F20 2.2 Stoker Kit
Baffled Sump
Aircon Delete Belt
Engine Mount Ring
Banned
Drive Train
Complete Transmission
Spoon S2000 LSD
Up Capacity Diff Case
Up Rated Diff Mounts
4.4 Final Gear Set
Drive Shaft Spacer Set
Lightweight Flywheel
Metal Clutch - Race
Organic Clutch Disc - Road / Track
Up Rated Clutch Pressure Plate
Up Rated Release Bearing
Clutch Slave Hose
Balanced Driveshafts
Spoon S2000 LSD
4.4 Final Gear Set
Metal Clutch - Race
Clutch Slave Hose
Banned
Banned
Interior & Exterior
Aero Front Bumper
Aero Rear Bumper
Aero Rear Diffuser
S-Tai Front Bumper
S-Tai Rear Bumper
S-Tai Bonnet
S-Tai Front Fenders
S-Tai Rear Fenders
S-Tai Carbon Diffuser
3DGT Wing - Carbon
Stainless Steel Front Grill for S-Tai Front Bumper
Engine Fresh Air Duct
Coupe Roof
Aero Mirrors
Wide Blue Rear View Mirror
Hydro Blue Wide Mirror Glasses
Spoon Steering Wheel
Steering Wheel Boss
Aero Front Bumper
Aero Rear Bumper
Aero Rear Diffuser
S-Tai Front Bumper
S-Tai Rear Bumper
S-Tai Bonnet
S-Tai Front Fenders
S-Tai Rear Fenders
3DGT Wing - Carbon
Coupe Roof
Aero Mirrors
Steering Wheel Boss
Banned
Banned
Originally Posted by tozerman
Crikey £247 each disc sorry mate but at that price I'll pay a bit more for PF 2 piece discs/bells, thanks anyway.
