Upper Mid-West S2000 Owners Members from the upper mid-west including Michigan, Illinios, Indiana, and Wisconsin
check engine light reset
Old Mar 7, 2005 | 04:14 AM
IBMcpa's Avatar
Default check engine light reset
#@$#@$ check engine light's on. last time it happened, i took her into the dealer within about 20 miles and they jacked it into the computer (like 6 different ways? under the dash, under the hood....heck, i had a guy at autozone check the light on my odyssey and it took all of about 3 seconds) and after a half an hour came back, rolled their eyes, and told me to tighten the gas cap appropriately.
strangely enough, i crank that sucker well more than 3 clicks every time...
low and behold, about 100mi after the next fill up, on comes the light again. i've retightened the cap, put another tank of gas in, and run the car the theoretical three days it takes for the light to reset itself. no dice.
tried to swing by the dealer saturday, but got there about an hour late.
8kmi on the car. has sat for 99% of the time since late november.
thoughts?
f'ing check engine light is making me more sick to my stomach than that little ding my wife put her it last week...
Old Mar 7, 2005 | 05:26 AM
S2000GT's Avatar
dont quote me, but i am not sure you can reset the light on your own...i know you can for the maintenance require light tho.
try tightening your gas cap harder
Old Mar 7, 2005 | 05:30 AM
Solless's Avatar
unplug the battery for a few minutes and it should clear the light, if it comes back on your are throwing a code somewhere
Old Mar 7, 2005 | 07:35 AM
Road Rash's Avatar
I had to do it once. I remeber it was some sort of combination of turning the key on and off while holding down one of the buttons on the speedo.
Old Mar 7, 2005 | 07:45 AM
Solless's Avatar
Road Rash you thinking of the Maintence Required light?
that requires cycling the ignition and holding the trip reset down.
Old Mar 7, 2005 | 07:49 AM
S2000GT's Avatar
Shawn - thats the maintenance required light reset
Old Mar 7, 2005 | 09:10 AM
Dezoris's Avatar
All you have to do is unplug the negative battery cable, for 10 seconds or less, just enough to make sure there is no power in the system.
It will cause the ECU to do a diagnostic start, if it throws another CEL right away after that something else is wrong.
The two most common annoying CEL issues are the gas cap and oil cap being loose.
If you are sure you have your gas cap tight, and get another check engine light take it back to autozone and find out what the CEL code is?
If it is anything fuel related REPLACE THE GAS CAP.
Old Mar 7, 2005 | 11:19 AM
revto9k's Avatar
plug the back up fuse, you can found those from ur interior fuse box. 3rd one down on the right, if I remember correctly. anyhow, the fuse is labelled backup. however, if something is wrong, the light will come back up
Old Mar 7, 2005 | 12:38 PM
IBMcpa's Avatar
is there some sort of pressure test they can do on a gas cap (i know they do something of the sort when the cars are emissions tested.
you'd think the dealer would have told me which code was coming up, but they were very evasive. i wonder if they're just trying to avoid giving me a new gas cap.
wankers.
will do the battery disconnect trick ( as i don't want to get my fat but under the dash on the passenger side ) and see if the light doesnt come back on.
you'd think for $30k+ these things would have some sort of readout via the digital display. heck, my 84 pontiac fiero would give you a cadence of dings that you could map back to error codes by simply shorting 2 pins on the diagnostic plug...
Old Mar 7, 2005 | 01:13 PM
S2000GT's Avatar
which dealer are you taking it to?
