Go Back  S2KI Honda S2000 Forums > North America West > Vancouver BC S2000 Owners
Reload this Page >
Blade Fuse size inside box - mini or micro?
Notices
Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Old 02-25-2019, 02:29 PM
Default Blade Fuse size inside box - mini or micro?
I'm hard wiring my dash cam and going to buy a fuse tap to the box. Are those blade fuses mini or micro size? Just making sure to buy the right size tap. I remember them to be pretty small and a pain to access. There must be an appropriate empty slot for it too. Sorry about the lazy question.
jon604 is offline
Old 02-25-2019, 03:24 PM
Chuck S's Avatar
There's both 12v constant and 12v ignition switched spade terminals on the inside fuse block. Someone will have the photo with little arrows. Camera can use an inline fuse all its own and connect there with a simple spade terminal. Ground to any convenient bolt under the dash.
Any reason, though, to not use the 12v always hot connection at the interior light right over the windshield? Would save a lot of wiring if you the camera always powered on or to come on if the car is jostled.
-- Chuck
Chuck S is offline
Old 02-26-2019, 12:08 PM
Sponsor
JS2k.com's Avatar
Mini Fuse
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
JS2k.com is online now
Old 02-27-2019, 02:17 PM
alSpeed2k's Avatar
-- Chuck
Hey Jon,
This is what Chuck is referring to.
alSpeed2k is offline
Old 03-07-2019, 01:55 PM
-- Chuck
Thanks Chuck. I won't use the inside lights because there's a voltage cutoff box on the wires that won't fit under the a-pillar trim. I'm not even sure about hard wiring it it because some say the voltage cutoff maybe too low and your car may not have enough juice to start.
What size are those blade fuses on the spots you've indicated? I'm planning to buy a fuse tap wire to put in there.
jon604 is offline
Old 03-08-2019, 08:03 AM
Chuck S's Avatar
The connectors in the photo are standard 0.25"/6.4mm male blades. Use a female "spade" connector available at auto and hardware stores, not a fuse tap. These are not fused so your camera will need an inline fuse. Doing it this way makes a separate circuit not dependent on some other fuse. If you choose the middle connector the camera will be active all the time. And also suck the battery dry all the time.
-- Chuck
Chuck S is offline
Old 03-12-2019, 12:56 PM
-- Chuck
I'm a bit confused. The fuse tap also had a fuse adapter built on top to add a fuse. I thought that would be helpful. I'd like the camera to be functional on parking mode so I need it on all the time. Though the unit does have a voltage regulator with the hardwire kit, I hear they can dip too low for you to start the car. I don't know if there's a easy fix to this without getting another external voltage cutoff limiter. The other option would be to use a USB battery pack and keep it charged. I just hope it doesn't explode in the summer heat..
jon604 is offline
Old 03-12-2019, 01:42 PM
Chuck S's Avatar
To my knowledge a "fuse tap" is a kludge/gimmick to tap into the fuse box at the same place as an existing fuse.
There are three(3) specific empty spade terminals on the inside fuse box to get power with a simple spade connector and not tie into an existing circuit. The ignition tap will turn the power on and off with the engine for example.
Your car will indeed fail to start if the battery voltage gets too low. Known and very effective way to kill the battery is something like a aftermarket alarm (which is no more useful than the OE alarm). A camera system could also do this if it draws sufficient current. Not sure what this draws but my GPS and microwave radio receiver can kill a battery in a week if left connected.
-- Chuck
Chuck S is offline
Old 03-13-2019, 03:06 PM
alSpeed2k's Avatar
The voltage cutoff box should go under the dash. It should have it's own fuse. Use a spade plug like this:
Plug the always on wire into D and the switched into C (per the picture above). Done! Or take it somewhere to get hardwired.
If you are using the fuse taps, then you can't really use the terminals pictured, you would plug it into 2 existing fuses.
kasher_khan
01-22-2018 05:05 PM
JackS
02-23-2011 09:53 AM
Mr. Francesco
03-30-2007 02:40 PM
Zonie
11-29-2006 01:18 PM
redleader
05-16-2003 05:57 AM
Quick Reply: Blade Fuse size inside box - mini or micro?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
